Oil cooling
219
4
CT
I was think about an external oil cooler. what is the beat way to do it.
I using the top of my oil cap for by-pass and soon oil pressure gauge.
any ideas where to tap it from. or is the oil cap the best spot for it.
Thanks John
219
4
CT
Never mind. I look at the Bible and the cap is the only place. oh well.
The only other place is behind the filter housing, down low. One of the sensors is oil temp, one is oil pressure. The cap is much easier tho.
6L PWR
Kansas Chapter member
7,961
255
Osage Beach, MO
For oil pressure, I put a T-fitting on my bypass filter out port and used it for pressure. That way I know I have pressure and I know if I have a problem with my bypass filter too.
Here's a pic: Click for bigger version.
bowtiehatr
Certified Ford Tech
the factory oil cooler is the best for your truck. it has the best flow of oil and the coolest coolant possible. both ports are like 5/8 in opening. i believe you would be wasting your money
blackhat620
You Had to be There
1,687
150
Arizona
Hey Todd, whose bypass oil filter are you running?
219
4
CT
Gald I was only thinking about it. I want this to be the last New truck I buy.
Now I'll think about some other way to help it last a long time.
blackhat620
You Had to be There
1,687
150
Arizona
Gotcha thanks for the replyYelloThumbUp
6L PWR
7,961
255
Osage Beach, MO
DOH!! My bad, I meant that the oil pressure sensor is T'd into the IN port of the filter housing. DUH!! There ain't no pressure on the out side!!
