wareagle
War Eagle
Does anyone have any tips/suggestions for installing a new one? Unfortunately, there is no switch currently in my truck so I have nothing to use as a reference point. Pictures would help also
Make a diagram of where each of the wires are in the plug, then remove them from the plug. Use stiff wire and thread it down the plastic sleeve. Attach the wires to the stiff wire with tape, pull it through the sleeve. Reattach the wires to the plug using the diagram.
I mean the plug on the new switch.Herein lies the problem. The "mechanic" that was working on my tranny at the time removed the old switch before having it shipped out here. And he ordered the new switch the day it was shipped. I have no idea where each of the wires go into the plug.
I have pulled so hard on steering wheel with both biceps that I broke the wheel and slammed my head against the rear slider.
Use a puller !
The connector will fit through the slot on a fixed column..but you have to remove the plastic connector on a tilt column.
I have photos and illustration of the proper position of the wires in the connector so you won't be stuck.
