Not so PSD
1970Custom
They call me Spuds
14,107
447
Middleton, ID
seeing as most folks here have nice new SD PSDs I thought i'd share my not so PSD.
So its not quite so purdy but it gets the job done.... as soon as there's a new clutch put in.confused
Any body else have an older oil burner to show off?:nana:
1970Custom
They call me Spuds
14,107
447
Middleton, ID
It needs a new bed, the current one is falling apart at the seams; I can't close the gate w/o a strap between the two sides.
When I do get it painted it will most likely be this color combo.
Its got the heart f a PSD.
That's all that matters.
1970Custom
They call me Spuds
14,107
447
Middleton, ID
What size is that goose neck and how well does that truck pull it? Reason I ask is because that is the primary reason I'm getting this thing running again, need a puller and my 5.0d F-150 just isn't going to cut it.
That goose is my father in law's 24', when I pulled it, I was running the stock setup completely, hadn't done a thing, and it did it ok, but was poochy. Now I run a 34' deck 2 car hauler, and while it doesn't set any speed records, it will do the job.Heaviest I have scaled with scrap hauling was 24,500, which floored me I was that heavy. I knew I had a load, but that was a bit much. It did it, pulled me down to 45 on some of the harder grades, but nothing like the mountains you have around there. Now when I had it out east to New York and Pennsylvania, Virginia, and West Virginia, it got more challenging pulling my sister's 5-horse trailer with living quarters. With the critters and all on, total weight was at 20,000. With 7 mile long 7% grades, it got me down to 30 at the worst, did that twice, the rest of the time, I held at 40-45. It also depends on your diff gears, I have 4.10's and a 4 speed. I can guarantee though it will outpull the 5.0... Mine gets right with it when you step into it. May not run down any 460's, but it will get going pretty good.
Gunner
57
Billings
Someday my truck will look like that :D Man that ain't a truck, thats a WAR WAGON. Thats what I bought mine for, to work it hard. There ain't nothing wrong with the looks of that truck man. That truck has TUDE :D
Gunner
1970Custom
They call me Spuds
14,107
447
Middleton, ID
You'll have to let me know how the ZF swap goes, but it may be a while before I can dish out that kind of cash...
1970Custom
They call me Spuds
14,107
447
Middleton, ID
The ZF was given to me by a mechanic of mine, its missing the shifter and doesn't stay in R, he said its about $120 for the gear and fork and it'll be good to go.
