Normal or Abnormal?
Hey Everyone,
I recently purchased a 1974 Ford F-100. It had a factory standard 302 in it, but when I got it had been replaced by a 351 Windsor. It currently has an Edelbrock 4 barrel carbuerator in it.
Now...for my question...I've noticed this, as it doesn't always happen, when I turn off the engine. It seems to on occaision sit there and sputter for a few seconds, at most maybe 3-6 seconds after I turn it off. Is this normal or is there something that needs to be adjusted/fixed/looked at to correct this problem? I've seen a bunch of older vehicles do this and have been told since the carbuerator is mechanical fuel injection, it is relatively normal for this to happen. Any input on this question/concern would be awesome.
Thanks everyone!
Sean
smilieFordlogo
LEB Kris
Kris
449
17
SC
its called dieseling....I guess because the engine sounds like a diesel when you turn the key off....and yes its rather common.
Check your timing (Im not too familiar with small blocks but it should be around 10* btdc inital) and that the carb idle is set correctly. (~800rpm is about right)
Dieseling. Had only one truck do it...
Kinda funny if it's someone else's but if it's yours it makes you look like a dumb ol' geezer trying to get to the liquor store at 10 AM for your bottle...
LEB Kris
Kris
449
17
SC
I resent that statement!
LEB Kris
Kris
449
17
SC
ok, maybe youre right but I dont think I reach geezer status for a few more years.
LEB Kris
Kris
449
17
SC
Think youve got me beat?
LEB Kris
Kris
449
17
SC
yeah I guess you do. 28
LEB Kris
Kris
449
17
SC
I got your chin whiskers.
Us older guys in the know call it Run-on...and yes it is caused by the timing being out or carbonized spark plugs still wanting to ignite unburnt fuel.
To everyone
Thanks for all the information everyone. I already know it wasn't the spark plugs. Those were pretty much the first thing I changed. I'll check the ignition timing tomorrow.
Thanks again everyone!
Sean
Jolly Green
I Salt My Ketchup
755
Central PA
I had this problem a while back and the guys here helped me out.
Two things: Timing did a lot for it. It still deisled a bit after timing, but not as bad, and not every time. After that, I started running higher grade fuel and it hasn't done it since. I think I read something about using the higher octane fuel in the write-up Mil1ion posted in my thread.
http://www.fordtruckfanatics.com/forum/showthread.php?t=13004
So, no more dieseling--just spending more money on gas in a truck that already gets 10mph!:headbang:
