makuloco2000
Certified Ford Tech
- 177
- 22
Now this has been a real common issue ever since Ford went to the inductive heating strategy for cold starts. Symptoms of a failing FICM are hard to start cold, no start cold and sometimes rough idle and die out upon starting cold. In this video I show you how it sounds and more importantly how it looks when it is failing on the scan tool and what codes are common. A quick replacement portion is also included. Now you can rebuild the FICM with parts kits through Ford but this one was not rebuildable and I show you why. I hope this helps.
