flareside_thunder
- 7,812
- 246
Hey James glad ya made it...like I said...a welcoming bunch of folks here with an endless amount of information.......I want the hood off ur truck.......and some specs on your engine build if you can........if ya need anything my contact info is on bottom of ALL my posts.
.which engine would you like specs for?
)and air inlet hose.never did run this combo on motor at the track but with a 125 shot(tnw plate behind the tb)it ran 8.43@82 1/8 mile.when it ran the 8.05@87 1/8 mile it had a stock 88 mustang short block with 165 afr heads,comp xe270hr14 cam,gt 40 intake,and 150 shot.these times were with 3.55 gears and the stock converter.as you can see there's not much difference between the times after you consider all of the mod's.the current setup was more impressive to me even though it's not as fast.just goes to show how fast you can go with stock stuff.the truck is also a little lighter this time around.
