- 68
- 0
I was on another forum and it seemed if you really needed some advice other than what type spark plugs or mufflers to buy you were SOL... I need some help,
I recently acquired a 76 F100. It has (and some supposedly) a 302 (from Advanced Auto), C6, 600 Holley, .471 lift cam, bored .30, and the distributor has been upgraded to non-points (electronic?) oh and an accel coil.
I adjusted the float bowls on the carb the other day and while i was cranking and so forth with the coil wire on and off I noticed it was corroded and there was corrosion inside the coil. I ordered new wires and a coil.
I received the new wires and took all the old ones off assuming they go back on in the standard firing order for a 302 and didn't pay attention to what they were before. I think, can't be a 100% certain, when I pulled off the old wires the #1 cylinder wire was on the #6 terminal of the distributor which basically diagonally across from the #1 on the distributor cap. The truck won't start now and will back fire through the carb about every two turn overs. Any ideas?
