never ever .. ever ... ever... but ever!!!
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
use kork gaskets on the waterpump!!!
the local store didnt have waterpump gaskets so we bought some kork universal ones and we made our own it was buetifully made withno errors yesterday i noticed a leak in thee waterpump area.. i removed it today since i got my new one to put VIOLA! just like magic the kork gasket disintegrated luckely it didnt get in the cooling system i found it all in the waterpump and on the timing cover...
:flipoff:
They make universal rolls of the blue gasket stuff too.
7,086
459
upst ny
RTV....never cork.
F 150Cobra
3,642
104
Aruba
i use cork and the RTV silicone stuff.. becuase i dunno if rtv silicone would work alone
7,086
459
upst ny
If it comes w/ gaskets.....throw them away. It'll leak.
This is 15-20 water pump install history(back to the '70s).
I'm just trying to stop an issue down the road.
I haven't had a problem with the gaskets that come with water pumps and I've done alot of waterpumps on many different cars.
What I do is do sealant on each side of the gasket and Ive never had a leak.
Same here...I do a thin layer on each side of the gasket and a thin layer on the pump...never had an issue.
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
Never used the spray copper... Might have to try it... Always done the rtv on the mating surfaces though like some on the pump, stick on the gasket then some on the block... good to go... Only use it on paper gaskets though, i think it messes with the cork gaskets...
F 150Cobra
3,642
104
Aruba
me 2.. but never had problems before..untill now i used Cork gaskets...
Old_Paint
Old guy with old cars
225
29
Alabama
I have to wonder how you think the cork did not go into the water jackets or radiator if it was shredded in the pump and stuck to the timing cover.
Here's my favorite gasket goo. This stuff stays soft, always tacky, and coolant will NOT affect it. Acetone (nail polish remover) removes it quite easily. It's about the only thing I've found that will stop a VW from marking it's territory.
DisplayImage.asp
I had to redo the timing cover and water pump gaskets on my blue bird after a dealership totally botched a long-block install. In less than 5000 miles, coolant was coming out faster than I could put it back in. Warranty? Umm, GASKETS aren't covered, and neither is the labor to install them. Gaskets are considered a "maintenance" item.
If I need something to set a bit harder, then this is what I use:
DisplayImage.asp
This stuff is good on trannies where there isn't nearly as much heat variation and problems with metal expanding/contracting constantly, or at different rates (cast iron vs aluminum).
Bottom line, I NEVER EVER put a gasket on without some sort of sealer applied to it. I NEVER use silicone (RTV) on an engine. Get one little bead of RTV in the right place, and you just toasted an engine. If HyTack won't seal it, or Indian Head, it can't be sealed, or it needs the sealing surfaces machined. The HyTack can be layered on a few times to make it nice and thick too. HyTack does not make beads when it squeezes out either, like RTV. Instead, it spreads along the seam it is squeezing out of, and forms a seal from the inside out.
But, you're right, NEVER use cork on coolant systems. The cork actually absorbs the coolant, and swells. This makes it turn the rubber binder loose and fall apart. Cork gaskets are good for things like valve covers, dif covers, or anything that can't be precisely matched like the front and back edges of the intake. Use the paper ones if it's going between two machined surfaces, though. I've used playing cards to make them for small engine repairs (lawn mower, etc.) when I was in a bind, or bringing one back to life that I didn't know whether or not it was worth spending any money on. Even that got a good dose of HyTack, though. Cork gaskets are typically intended for sealing two items that cannot be torqued down tight. Your water pump can, and should be, according to spec.
1985 Ford F-150
Country Boys Can Survive
7,816
307
Tooele, Utah
This is what I use.
https://www.neverseezproductscart.com/shop/product_info.php?products_id=399&cPath=106#googlebase
Its kinda hard to get back off but if ya have a good quality scraper or wire wheel either on a drill or a bench grinder it comes right off. I use it on everything and I have the one that comes with its own little caulking gun to make it easier to use. The cans always run out about halfway when all the gas escapes. They have it at any auto parts store. Ive also used that stuff alone on water pumps and it holds just as good as a gasket. Theres also no fumes like silicone has and it dries quicker. I spread it out on the part with either my finger or a pop cicle stick so it dont pooch out the sides.
F 150Cobra
3,642
104
Aruba
Got the new waterpump with Gasket and also got this stuff..
DisplayImage.asp
looks really good!
