Need throttle solenoid.
10
Can not find a throttle solenoid as pictured below.
Any ideas on where to locate.
I will try pick'n'pull if necessary.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
1985 Ford Lariat F-250, XLT, 4x4, 4 speed, 460ci, Washington state.
There are two different types of these parts. One type is called a throttle modulator .. the other is called a dashpot.[/I]
Is the carb ID tag still present? It's triangular shaped and mounted to the air horn, has an ID number stamped on it.
There were 4 different carbs offered for these trucks, without the tag number, there's nothing that I or a parts guy at a Ford dealer can do for you.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
found this tag: E3TE PD
D9PZ-9503-B .. Throttle Modulator Assy - Use with tag # E3TE-PD (Motorcraft CM-3207) / Obsolete
No Ford dealer or obsolete parts vendor has any.
Auto parts stores can cross the Motorcraft part number over to the brands they sell.
Thank you for replying.
No luck so far with parts stores. Next stop junk yards.
How about a speed control cable?
Had a fire. Lost everything on the driver side of carb.
