Need some wiring help ASAP!
1977 EXPLORER
Tennesee Chapter Member
Hey guys Im doing a truck/van motor for a swap into a older car and I need some help identifying 4 wires I believe 2 of the to be the oil pressure sender and the coolant temp sender but have no idea..
I appreciate ANY help! Stuff came out of a 90 E250 van motor is a 5.0 and AOD if that matters should be the same as an f150-350
These are on the "firewall" section of the wiring harness coming out of the colored plugs on the firewall were they plug into the injector/ignition/etc harnesses.They went into the BODY (larger round connector) portion of the van and not the PCM plug (retangle plug)
wire color/Tracer
black/purple (could be pink)
white/red
red/white
white/pink
Wire colors
these plugs are normally mounted inline (just to show what plugs i was refering to)
And a pic of the swap 'hiding_smilie'
wire color/Tracer
black/purple (could be pink) BK/PK = Backup lamps ALSO Wiper motor from groverner
white/red = Oil Pressure
red/white = Coolant Temperature sender
white/pink = To Backup/Neutral safety switch
1977 EXPLORER
wire color/Tracer
Thanks a ton looks like they can be cut.
:beer:
