bigdogdiesel
Certified Ford Tech
If anyone can help me i have an 06 f550 6.0 l that will not restart only when hot, have replaced hp oil pump and stc fitting, also stand pipes 2 injectors and dummy plugs in both manifolds, tech line is not much help just putting more parts on, i can here a faint leak only with eot above 180, truck will crank for awhile then start with eot below 180 degrees,, also truck starts and runs great cold no drivability issues felt or seen with ids, ipr reads 25 % cold and up till eot 195 then starts to climb to 30% but if you give throttle and let return to idle ipr returns to 24.79% then 25%, i think its a branch tube but no hard proof, tech line had me replace new hp pump due to low icp when both heads blocked only gets 890-900 psi. any help would be great.
