need help again
I finally found a "baby C6" for the 1985 Ford F150 with the 300 six cyl but it came out of a 1967 mustang with a 302, will it fit. I bought a flywheel from the auto parts for the 6 cyl There are lots of big block parts but not any smal block and also lots of C4 thanks again
primetime
sawmill slave
1,495
64
Onaway Michigan
It`ll bolt up. 300 and 302 share the same bolt pattern. The only issue may be the shift linkage. I had to change the shift linkage on a gen 6 big block trans that I put in a gen 8.
Starters and block plates are also different between manual and autos.
3,291
188
In my own world
Block plate is the tin that goes between the block and trans. I forgot to put it on my ranger years ago, and it ate starters.
Just a note, The car transmissions have different gear ratios than the truck ones. Usually 1st gear is lower in the trucks. It may be a bit sluggish on take off.
