Need expert help! Pitman Arm
Storm
Registered User
1,320
32
Round Rock, TX
Ok.. My dealer as royally pissed me off.. There has to be a better solution!
I let my buddy's at Ford install my lift kit awhile back.. Somehow, someone mentioned how they tore it.. Anyways the boot that is on the bolt for the Pitman Arm drop cracked.. I went back to my buddy and he said the only way to replace that boot is to buy that entire arm.. I'm not spending $$$ on an entire piece that I won't need when the only item I want is the boot.
Does anyone know of an alternative, or where I can get just the boot? I'm afraid that over time it's gonna get dirt up there and eat my bolt away and bam there goes my steering..
if you can find an old arm, possibly use the boot off of it.
Storm
Registered User
1,320
32
Round Rock, TX
Is there anything else? Aftermarket boot.. Anything.. Whats worse case scenario with that boot being cracked.. I just really don't want my steering to go kapoop while I'm on the highway!
keep grease a'plenty in it. It'll be nasty but the constant greasing will "flush" out any contaminates. It does have grease zerts,yes?
bowtiehatr
Certified Ford Tech
the boot is not for the pitman arm, its for the drag link. aftermarket companies do make the boots. call your lift manufacturer and see what they offer.
Storm
Registered User
1,320
32
Round Rock, TX
ahh Draglink.. Pitman arm.. All I know is its the bushing underneath the Pitman Arm drop..
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
If you are speaking of the rubber cup shaped device that fits over the stud on various draglink and tie rod ends, Ford sells them. I don't have a parts catalog after 1991, so I can only give you the basic part number: 3332.
Storm
Registered User
1,320
32
Round Rock, TX
That boot right there infront of you.. That's the one I need to replace :)
6L PWR
Kansas Chapter member
7,961
255
Osage Beach, MO
Looks like your regular tie rod boot. I'm no mechanic though. :)
