Need a new exhaust
18
My exhaust has a small hole in it and is starting to get bigger. What do you all have for exhausts? Keep it stock or something else to change the sound? I have a '90 F350 7.3 IDI
I reworked my 86 6.9 a bit to get better flow. I made the y-pipe actually flow instead of just dump 90 degrees into the other pipe, then opened it up after the y into 3" pipe. I have been told that using factory powestroke exhaust after the y pipe works well also.
Sparky83
Virginia Chapter member
5,571
226
Norlina NC
if your good with a welder and dont want to spend the money right now you could try welding up the hole.. but usually once a hole starts forming in the pipe its really getting too thin to last much longer..
For an IDI, your factory system does about the same... Powerstrokes by nature have a little larger pipes, so when someone takes the factory one off for an upgrade, it is a good grab for us NA IDI guys.
