EVERYTHING so far it seems has had to be replaced. I mean NOTHING worked on this truck. The aggravating thing is that if the DPO had done regular maintenance and fixed things as they broke, I wouldn't have to fix all of it!
So far here's what I have replaced or repaired:
* brake shoes, all four corners
* wheel cylinders, all four corners
* wheel/hub bearings, front
* electrical issues with all lights but headlights not working
* instrument cluster (broken speedo, temp, amp gauges)
* removed crappy body lift/replaced body bushings
* replaced e-brake pedal and cable
* plugs, cap, rotor, wires, air filter.
* adjusted timing
* had no fuel filter, added
* radius arm bushings
* front outer/inner brake lines
* bell crank/clutch release and bushings
* clutch/brake pedal assy.
* clutch rod
* removed brush guard (was for diff model vehicle)
* removed side steps
* removed slide-in bed liner that was for diff model vehicle and cut to fit.
* removed warped tool box
When I got it, the fluid in the radiator had so much 'stop leak' it was the consistency of pudding and there was no thermostat or rad shroud. Now that I have it flushed out for the most part it has started leaking. I will just replace it since there are signs of previous repairs on this radiator.
At least it's rust free!
