- 147
- 1
Very nicely done.
Im not much of a fan of Eagle cranks but for your intended use I sure it will work well. With your piston choice I assume you will be using small valve D3 heads?
Actually, pending funds, I will be going to Kaase P-51s. My connections can get me a set dirt cheap brand new. I'm going to hog the chambers out from 72 to somewhere in the 80s I found a build sheet we have at the school that a 534 made 770hp at 6300 and 10:5 compression. Same internals except a larger bore. Same heads. So that's where I'm headed. That's around the range I want. Project has been put on hold til I can afford the heads though.
