Moisture..
Mr. Stroker
CASE IH
3,121
67
Michigan
Is it bad to have moisture in my off road light? they are brand new KC's and it looks like crap with one foggy and one clear! WTH! Just noticed it as i was uploading pics from today..
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
When they turn on they should clear out. I never found anything to work on mine. I've heard of guys drilling a small hole in the back at the top, but never tried it myself!
Mr. Stroker
CASE IH
3,121
67
Michigan
I was just thinkin if i turned them on it would probably clear up. But still it should be sealed rite?
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
That is why I never tried to drill them. I now have 4 $30 lights on the front....they have no moisture but I'll be damned if I ever buy them again! I want my KC's back!
My 6 KCs never got moisture in there, you can take it apart and clean it out, and if u wanted seal the hole where the wires come in, and use a bit of RTV to seal the front, dont go crazy or ull never get em apart. Ive also drilled holes, it works, id put it on the bottom not the top.
TexasNomad
FTFS Designated DRINKER!
On my friends Rig we took the lens off and cut a new gasket out of a sheet of rubber, that fixed it not sure how long he sold the truck soon after.
blackhat620
You Had to be There
1,687
150
Arizona
1,320
82
Shouldn't have happened in the first place if they were properly sealed. Hopefully they will clear up or you will get warranty or something. nice truck by the way.
Mr. Stroker
CASE IH
3,121
67
Michigan
I was thinkin bout calling them, such a PITA now... Il give them a ring. Thanks for the help everyone
973
11
get a silica gel packet.. tie some fishing ing around it, put it in the light and put the bulb in to make the seal.. let it sit in the sun for a few hours and DO NOT turn on the light..
after that the light should be clear and you can remove the packet and ur good as new!
973
11
any update on the lights? try my idea.. swear it works!
Mr. Stroker
CASE IH
3,121
67
Michigan
ive been to busy to acually sit down and call them. Sorry but if they warrenty im not drilling anything lol
973
11
no need to drill for the silica gel trick!
