I have a plastic tank(original, I believe) midship on a 1978 F-150(49 state emissions) 4WD with about 22.5 gallon capacity +/- that is leaking around the top of the tank at the hose inlet area. I don't know if the leak is coming from the old cracked vent-hose or from the tank itself. The tubing that the hose connects to on the tank seems awfully loose. It doesn't pull out, but there is a lot of flex in the connection to the tank. Is this normal?
Also, I've been looking at replacement of the tank. All the listings that I can find for a plastic midship tank with 22.5 gallon capacity are for 2WD application only. Is there a difference between 2WD and 4WD midship tanks?
The midship tank is mounted inside the frame rail in a metal shroud that is in pretty bad shape. If I replace the tank, do I have to remove the bed? I can get at the fuel filler hoses from underneath, and the sending unit connection is located on the side of the tank away from the frame rail.
Any thoughts?
Any thoughts?
