measuring valve guide wear
When using a ball gauge to measure wear on valve guides, what type of wear would you expect? 1) more at the bottom 2) more at the top 3) equal wear all the way down 4) wear top and bottom, less in the center
6L PWR
Kansas Chapter member
7,961
255
Osage Beach, MO
I vote for top and bottom. I don't want to explain cause it might make me sound dumber than I am. :D
blackhat620
You Had to be There
1,687
150
Arizona
I select answer number 4, more wear top & bottom with the least wear in the center.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
I say thats what my machinist is for!!!ROTFLMAO
mrxlh
Oilfield Trash
5,904
430
Stigler, OK
Wear at top and bottom and less in the middle.
I'm going with number one. Assuming the lash had been properly maintained, the rocker arm holds the pushrod fairly steady at the top, albeit somewhat, and the guide would get a more conical wear; Narrower at the top, broader at the bottom.
mrxlh
Oilfield Trash
5,904
430
Stigler, OK
Ok Vince, so when are you going to give the answer? :rofl:
OOPS! The movement of the rocker arm will cause the valve stem to "rock" back and forth, causing wear at the top and bottom of the guide. Overhead cam engines with valve followers lessen this type of wear.
