Can someone help with some info on the limited slip set up in dentside axles? I'm not confident enough in doing my own gearing work, so I've only cracked open diff a few times. First I'm assuming the LS is a torque sensitive setup as opposed to a speed sensitive setup right? Secondly, at what torque rating does it take before the LS actuates before engaging (ie how much slip does it allow before engaging)?
