Love the 3, in F350
Had to pull some trees down, cut em up, hauled em out.
Looks level now.
Lets see some heavy loads.
Chris what the hell tires are those?! First you had 36's and then like 31's... Those look more like 33" M/Ts...
Looks good man...I've had 3-5 ton dies in the bed of thunder on several occassions.
There the 36x12.5x16.5's GY Wranglers RT/II's
Most I have had is 38 80lb bags of concrete in the back of mine... like 3000 lbs?
Man you're truck makes em look small! Time to step up to bigger tires :D
The truck is too low in thr front to go bigger, plus its slow enough with them on, if i went bigger id have to do some gears.
Do it Do it do it (in a chanting voice)...a regear is one investment you'll never regret. The 4.56's in Thunder are perfect with 37's...shim out the front bumper like I did, and you'll clear bigger rubber.
Is there any thing these trucks can handle :D
No there isn't...if there was...they'd be called Dodge/Chevy/Yota/Honda...that's the short answer anyways.
Shimming the bumper doesnt look good to me, i just cut the inner lip off with a sawzall, required much less effort and still looks stock. Plus with my plow stuff on, if i shimmed it, it would hit the plow mount. With the inner lip trimmed it looks stock still and no one could ever tell anything was done. I dont want bigger tires. 36's are big enough and looks good on her now.
