Looking for bushwackers
Hi. I'm looking to put bigger tire on my ex and I want to get the cut fender flares for it but the bushwacker site doesnt have any? Any one else have them? I'm specifically looking for the part number for them or any ways to modify ones off a super duty.
blackhat620
You Had to be There
1,687
150
Arizona
The front SD PU Bushwhacker Part # 20043-02 will work on the EX as the front fenders are the same, your problem is going to be the rear. There is very little room between the rear door and rear fender opening on the EX. You may be able to modify the rear SD PU short bed Bushwhacker Part #20044-02. The rear set will probably take quite a bit of modification so it is going to depend on how good your fabrication & body skills are and how much actual material can be cut away before you compromise the door pillar.
