Looking for advice on exhaust
dreamison
Texas Chapter member
Hello,
Just finishing up the install of my explorer 5.0 with MAF conversion in my 1991 f-150 4x4, E4OD. I used the truck exhaust manifolds for now, I still have the factory Y pipe but have reduced it to a single cat. I have heard good things about the flowmaster 50 series and am thinking of giving it a try. I am trying to figure out what size to go with, I am thinking 3" single all the way back but I don't know if thats the best way to do it. Also should I clear out the front cat or leave it alone. Would do more but need to make some more money first. Blew my wad on the new motor.
I think a 3" single will be the best way to go. If you feel the need to go duals, I'd go no bigger than 2.25" pipe. Never really been a fan of gutting cats, if it were me, I'd go with high flow cats. As for the muffler, do a youtube search and you'll be able to do comparisons on sound. Personally, I don't like FM's and would go with something from Magnaflow or Hooker.
flareside_thunder
7,812
246
3 Inch should be ok for what you want. I'm assuming you made some mild mods? Also, the Dynomax has proven better numbers than the flowmasters as has the Magnaflows. Just a thought. You could gut that cat if you wanted....but it'll just act as a resonator which still restricts flow. I'd actually suggest redoing the exhaust with a 2 into one setup minus cats.
dreamison
I have used magnaflow in the past with good results, but i'm not looking for big sound, just nice mellow sound. When I can afford it I plan on magnaflow high flow cats. I just need to put something together with what I have now with a new muffler and I will do a turn down behind the muffler till I can get a new pipe out back.
fordman76367
426
4
id go w a 3'' single lose the cat and pop a glass pack on er'....nice and mellow but growls when ya giv er hell....maybe megaphones or dump tips
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
3" is to much for the 5.0 imho... Unless its not truly a 5.0 anymore...
2.5" will be plenty an engine does need some back pressure to run most effeciently...
KdPate
After Hours Garage
I change over to the Bassani y-pipe w/ cats and run a good muffler int a 3" single exhaust. I'm running tri-y/ long tube combo and I have pelenty of power on the low end and run like a bat outta hell trying to get down 840 with a trailer behind me....
Link to the buildup of my exhaust system.:wasntme:
http://www.svtoanashville.com/forums/showthread.php?t=4650
3" single is a good way to go with the muffler of your choice.
dreamison
Exhaust is done... new y pipe into single 3" high flow cat with single magnaflow 3" 5x8 oval with a turn down. Sounds great and looks good too.
