godblessmud
CHECKERS OR WRECKERS
Wow.
Did you compensate for the change in the odometer?
Had to add 12.8% to the miles on my '75 since ~1980.
Had to add less than that from ~1977 to ~1980.
Alvin in AZ
Sadly...yes it was adjusted
Wow.
Alvin in AZ
lol I am also looking for a lift kit and am looking at the rough country 6" w/ the springs, not blocks. I am running 33x12.5 BFG All-Terrains and the poor stock suspension leaves me only 2 fingers worth of room between the fender and my $150+ brand new tires. (replaced two w/ problems, other two were almost brand new anyway) I have a 1990 F150 4x4 302 5spd reg cab short bed. I want a bolt on kit so I can do the work myself w/o too much trouble. I do not "plan" on doing any heavy duty off roading at this time. (for now anyway) I also must retain my dual front shocks. I am not as concernd about a "good" ride as I am performance. I highly desire that it be a full "kit" with all needed parts to run safetly. I want my truck to ride like it is a older full size 4x4 truck, not a car. (keeps away annoying passengers) Any reccomendations?I am keeping my stock rims and I already run 33" tires, whicher brand new. I just want more room for my tires and some more off road capability. My stock suspension is worn out and I want a lift kit to replace it with. I refuse to part w/ my tires n rims, I love the look of the old stock rims and these tires are awesome
i would advise against rough or tuff country kits or anything that uses rear blocks instead of actual new springs
not to mention that a 6'' lift for 33's is a bit overkill. 4'' is cheaper, looks better, and is less work to get it to function properly.
my 0.02
Yeah, but for 4" you can't get Deavers.
Bolts stretch, thats why you retorque. They always settle in a bit too so should be checked anyway after some use. Don't foget tires types weight different than each other, besides size effect fuel mileage. Oh yeah a 460 with good fuel econo, ha ha.![]()
drop radius arm brackets and drop ttb brackets. both are bolt ons
