Lighted Visors!
You have to run the wire from the mirror down the pillar to behind the dash.
You're welcome :)
885
53
It runs down to a connector that hooks up along with the glovebox light wire. It is a green wire behind the dash.
It has a special connector at the visor and a bullet connector for the dash. It plugs in to the 3 terminal connector is for the glovebox light. If you did not have a lighted visor originally the truck will not be wired for it.
Yeah I had to install that wire with the 3 terminal connector for my glovebox light. I shouild have mentioned that. Thanks for the correction.
Green with a yellow stripe I think.
Fordzilla80
Ranger Lariat
6,372
262
Narnia
Well, if the colors are the same as my truck, i'm guessing the lighted visors run on the constant 12v power source circuit? So the visors would be usable even with the key off and away from the truck?
