Lift kit question
My 4 inch rough country lift showed up today and i was just reading through the installation instructions, it says front lower coil spring retainer plate has to be modified to fit the larger coils. Anyone installed one of these puppies and modified these so that i can have everything ready to modify it when i go to install it. Basically WTF do they mean by modify ( weld piece on, grind it down , bend it ,)??????
UNRULEE
^LARGE carbon footprint^
5,412
424
Coal Country, ND
I never done a lift on a 150 but, I'll guess and say that the plate more than likely has to be bent because (I think) the new coil springs will be of a slightly larger wire diameter............maybe someone else knows for sure???
well this is what i want to know, if i have to make fab something up i would do it before i start hauling it apart. anyone ??????
I can't remember what the exact modification is, but I believe it's to prevent the spring from bowing. I know I see it discussed from time on FSB.
