lift/carrier bearing
5
i have a 95 f150 ext cab with standard bed so obviously two drive shafts... but im planning on lifting it quite a bit soon and wondering whats the easiest solutiion to this drive shaft problem. do i just lower the carrier bearing? aand if so how? or i was thinking that maybe if i go the divorced case route itll shorten the distance enough to just replace both with a single driveshaft.... idk help?
You can use square tube to make a spacer to drop the carrier some.
