- 7
- 0
2005 ford diesel 6.0 wont start,when the batteries are at full charge the motor only cranks , but when they get low at aprox 40% it tries to start and with lots of black smoke. I repaired high pressure oil leak , diagnostic shows 6 of 8 injectors failed click test. I pulled injectors had them checked and they all work! The ficm shows 48 volt with key on and when cranking.The high pressure is at 1500 psi when cranking. fuel pressure is arround 50 psi when cranking. there is no chaefing on wire harness and all plugs are cnnected. I also let it sit over night with out recharging the batteries and the next morning it tries to start right away, but whe i charge the batteries back up it only cranks over until they get low again then tries to start. Can anyone help
