polarbear
just growing older not up
Had an intermittent stalling issue with the F150. Would run fine for 10-20 minutes, then quit running. Surface streets or freeway- didn't make any difference. If it sat for a few minutes, would always restart. Replaced the coil- that wasn't it. This can be a potentially frustrating problem, because there's so many potential causes. Computer claimed it was running lean on both banks, but never triggered a check engine light.
In our case, turned out to be a fuel pump relay (under the hood in the engine/ECM fuse block). Cheap part- about ten bucks. Wanted to post this in case anyone is faced with the same issue.
