Manimal
California Chapter member
- 64
- 2
I picked up a 1979 F350 S'Cab Ranger XLT just recently. I went to remove an added on speaker from a PO install,and had mouse poop fall out of it!
So the more "involved" I got with ti, the more poop I found!
I kinda got freaked out when I stuck the vacuum hose into the AC ducts and it sounded like SAND being sucked up! Hantavirus crossed my mind real quick! So I stopped and called my Dr. to see if any tests were available for early detection...he said no just watch for flu like symptoms!
...so far so good. Been 4 days and no symptoms, so back to work...only with gloves and a mask!
So I removed the instrument bezel and found my source for the poop!
This one was laying on top of the instrument cluster!... then I removed the clutster and found his friend!
So out came EVERYTHING inside that cab except the harness...
I then sprayed it all down with bleach and water mix,let it sit for a few minutes and hosed it out!
I pulled all the AC ducting out and bleached it as well...
Including the dash...
Now all I have to do is scrub it all down with hot soapy water and start to insulate and sound proof. I plan on removing the headliner while I am in there and insulating the roof also and fixing a small rust spot.
I ordered new carpet and kick panels from Stock Interiors. I still have to replace the heater core and may as well do a blower motor while I am in there.
