Well after all the hub bub with the Bronco, I found solice in Red that I could hop in and go anywhere with absolutely zero problems. Well yesterday and this morning begged to differ.
-I hop in last night, I turn the head light switch so the dome will come on. No such luck. I open the door and the light is on, but will not come on with the head light switch. Time for a new switch.
-It's down pouring last night, and I realize I only have one speed for my windshield wipers. Low speed came on just fine, I turn it to high speed, it remained on low. Loose wire or maybe time for a new switch.
-While driving last night, the left hand side of the dash panel decided to burn out. Probably time for a HIPO LED upgrade.
-This morning I hop in to come to work. The first time I use my turn signals, they come on solid and won't blink. They cancel just fine though. I also have e-flashers, so I'm assuming the signal switch either broke or shifted.
So no real issues, more venting than anything, unless I'm wrong on my diagnoses, then as always post away.
