Ummmmm.... How do I do it?
aftermarket? its super easy actually. can do it in 30 mintes or less.
if so how many wires?
4? red, white, black, green?
I see. I'd have no issues with illum and power etc. But I don't know what's up when running off of the coil.
when you get a chance take a picture of how your coil is setup. im thinking itll be similar to mine.
mine has 2 wires going into the connector that attaches to the coil. what i did i just had my truck running and everything hooked up and then took the bare end of the green wire and put it on one wire at a time in the connector and whichever one made the tach jump up i spliced into.
Will do. Trial and error with it...
Not having a tach is really killing me.
was me too. even though its an Auto i like to see what RPMs im turning..
plus im gonna have to have one so i can break in my cam when i get my chit together...
I has factory tach.![]()
bwahahaha wow. you dont even know if it works?
you aughta do a Old start, Cold Start since its been sitting for so long..
I've decided not to run the truck anymore.I don't wanna risk any more damage to it.When I first got the truck,I didn't care for the 300,so I put it through hell.So now,i'm gritting my teeth on whether I can even use the original block.The inside of my water neck is corroded to hell which makes me wander about the condition of the internals.
Plus,my battery crapped out,and I accidentally let the warranty out,and i'm not paying $100 bucks for a new one.The truck sits so much that another battery would just lose juice again,and i'm not buying a maintainer either.
So she sits until I pull the 300 and rebuild it.Next summer?
psh... wussy...... just starting it up won't hurt it...
I'm not taking any chances.I'd like to re-use this block.
300 blocks are plentiful. why is it so important to reuse this block?
Because it's cast 09/79 and it's numbers matching to the truck.Remember,i'm trying to keep most of the driveline in this truck original.The only thing in the running gear that won't be stock is the gears,D44,and offy intake/carb/EFI manifolds should I do that swap.
