Hey fellas...I'm in a little bit of pickle. I was replacing my tstat today, and was almost finished. I went to tighten down the last bolt, and it broke. The bolt is flush with the top of the block. Are there any suggestions on getting this bolt out? I tried tapping it on an angle with a center punch to try and see if I could get it to back out enough to grab with a pliers. No luck. I tried to JB Kwik the two halves back together to see if it would hold long enough to back out the lower half. No luck. I also thought about cutting a notch in the top of the bolt so I could get a screwdriver on it...but here again, no power outlets. Next idea is to get that broken bolt extractor kit called Grab It...you guys think this will work? I'll also need to get a cheap battery powered drill that is up to the task. All I have are corded drills, but I'm at least 300 yds from the closest outlet. Any suggestions for a drill? Thanks for any help.
PS...I knew it was going to be a bad day when I dropped a socket and it rolled and fell into the only drain within 200ft. On top of that, I slipped with my gasket scraper and sliced my forearm...probably need 4-5 stitches, but I have it butterflied up for now.
Thanks for any help guys.
