i need to remove the engine harnass from my inline six truck to sell it with engine
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
how do i get the harnass lose from the truck to go with the truck only the ECU and connections??
the ecu is connected to everything ... arg...
Lost
PA Chapter leader
3,288
central PA
Now the pain of efi to carb is coming into view. The new motor owner will probably want whole harness if he is putting a 6 in a 8 truck . But just give him the fenderwell to motor harness it has a big plug unbolt and take off. that way your not cutting wires or pulling pins till u decide what way you want to wire it .
I took a older card equipped 300-6 harness and made connection right at incab plug . (did away with ecu plug ) And used both new and old to make the harness I needed with all ignition ,lights etc. The only thing I did is went to motor mounted fuel pump and your probably going to use factory pump setup.
Good luck
F 150Cobra
3,642
104
Aruba
no he is putting in a 80's truck wich was an i6 already im gonna cut the wires that go to the passenger side of the truck
map
ground
and get him the ECU and whatever else its his problem to mes with it lol
i dont wanna cut the whires of the headlights and stuff
