I have 88 f150 with 5.0 truck runs good at idle engine revs fine go to drive it runs fine for two or miles then loses all power backfires turn off the key for 5 min runs ok again for a mile or two then the same thing any help please
Pull the codes and post them.
It sounds like the TFI is heat soaking and breaking down. Not sure if your engine has a Pip sensor that could be breaking down also causing this.
