i dont need the front tank i want to remove it.. possible??
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
i want to remove the front tank.. i can remove it easely but what about all the fuel lines and electrical lines??
reasons
1. fuel pump doesnt work ( i can replace it but nahh.. )
2. why do i need all that fuel for? i wont go on any long trips ;)
reasons
Keep it there, but dont fill it... [confused]
Why remove it? If you leave it, you can fix it for later. And besides, buy a bunch of cheap gas now, and save it for when the price shoots back up... :p
F 150Cobra
3,642
104
Aruba
haha the 3rd most important reason when i drop my 5.0Ho i can run true duals.. exiting in front of the tire
TexasNomad
FTFS Designated DRINKER!
I'm not sure but I would think both tanks are plumped in to one pump I'm sure you could take the tank out and plump the rear tank in to the pump.....
F 150Cobra
3,642
104
Aruba
nope every tank has separate pumps.. and 89 doesnt have the rail mounted pump like the 87's
Yeah this is no problem at all. I made up plugs for the fuel lines from a couple automotive studs(the OE type with an integrated nut), simply cut the threads off 1 end and grind the nut to clear the fuel line retainer clip. On the older trucks the connector is plastic and the retainer is more like a C-clip than what's in the pic below, but this should give you an idea of what needs to be done. For the electrical connector simply wrap it in a plastic bag and tie it up out of the way.
radialarm
Clown of Death!
