If you own a late model truck, you are pained by the acres of always fading black plastic trim. There are plenty of OTC remedies to pretty it up for a week or two, there are dyes that last well over a year, and then there's the best option for that new, deep color - spray paint. I'm not talking Krylon or Rustoleum, think better. SEM is a leader in color match vinyl and plastic dyes/paints, and is my go to for the ultimate trim restoration.
What you'll need to get the job done right:
- Assorted painters tape, 3M blue does the job (Spring for the fine line if you can). I generally carry a few different widths.
- Alcohol, Mineral Spirits, or Acetone.
- SEM Trim Spray (39143 -or- Bumper Coater)
- A well-ventilated work area and a face mask. Gloves are also helpful.
Step one: Thoroughly wipe down the plastic to be sprayed with your prep chemical. My go to is alcohol. Use a lint free cloth or towel. Be sure to wipe the edges and all of the corners. This prep will help for a great finish.
Step two: Tape off any paint around the plastic to be sprayed. Most trim pieces sit with a slight gap off of the paint. Try to position the tape behind the trim to avoid any overspray.
Step three: Following the directions on the can, spray the plastic piece. Light, even coats. Don't rush this step!
Step four: After spraying, using a clean microfiber towel and some alcohol, wipe any overspray off of your painted surfaces. Be sure not to get the alcohol on rubber, vinyl, or plastic!
Step five: Remove tape after paint has dried and enjoy your results! Make an attempt to allow it to cure in a warm area away from moisture.
Before:
After:
Before:
After:
