How the heck.
TexasNomad
FTFS Designated DRINKER!
I'm installing my new one wire super alternator and some thing smacked me in the face like a ...
Any ways, one dig on this the positive cable goes from the bat to the Alt.. some thing isn't right here..
this is how the installation guide says to install it..
High Output 200 Amp One Wire Alternator
"1 Wire" means Positive battery wire to alternator only(4 gauge or larger)
No other wires needed
No modifications to the stock bracket or pulley system needed
How the hell is the truck going to get power!
Am I missing s ome thing eher????
surewhynot
Rep whores make me sick
13,843
821
Florida
The truck will take the power from the alt via the battery.
TexasNomad
But how....
Its one wire from the bat TO the Alt no where else .. there is no wires going any where else so how the heck will it get the power from the battery?
surewhynot
13,843
821
Florida
Where do your wires going to the truck hook up now? You might have to move them to the solenoid.
TexasNomad
What...
WHAT!
Ok..
One wire hook up one 1 wire no more no less One being the number of the wire 2 being to many and 3 is just out of the question.. 4 is right not..
wire.
Form battery
To
Alternator.
No other wires
going any where.
Just 1
Do I need to take a picture of this?
You leave everything as it was before hooked to the solenoid and anyother power feeds you may of had. you take the power wire from the alternator and hook it to your battery. It's a one wire alternator, not a one wire system. Basically you'll have one wire going to the alternator and one wire to the solenoid. You'll also have a wire coming off the same side of the solenoid to feed other systems in the truck. I think that is how it goes. It's been a few years since I've played with one.
TexasNomad
Well i guess my trucks been messed with over the years, because my battery cable was bolted on to the solenoid, so I need to run two cables one from the bat to the solenoid and one from the alternator to the battery..
Any ways!
guns great! and even cooler :) my fuel filters are both full now no more surging :D I should have done this years ago!
Oh and thanks to the Tonymyster!!! for helping me get it running :D I would rep you but it says I suck eggs :(
You got any before/after/progress pics Tex?
TexasNomad
Ok! these wires
Hooked up to the alt here
The BLACK cable is how the original cable was hooked up ever since I owned the truck. from the bat to the solenoid..
So when the paper said "run one wire from the bat to the Alt" it really chunked a monkey wrench at me.
UNRULEE
^LARGE carbon footprint^
5,412
424
Coal Country, ND
I'll upload a pic of my complete 3g set-up.................................
UNRULEE
5,412
424
Coal Country, ND
OK, snapped a pic.
You're wired correctly, but you need to get a Maxi fuse in there. If that big 3g ever faulters and goes full field a fire won't be far behind!
Here's what mine looks like. (complete with Optima battery, red top though, not yellow)
UNRULEE
5,412
424
Coal Country, ND
UNRULEE
5,412
424
Coal Country, ND
I got my whole 3g set up from Pa-performance. Maxi fuses are kind of common though. If you have a fork lift dealership nearby they should be able to hook you up.
