How Much and What type?
Mr. Stroker
CASE IH
3,121
67
Michigan
How much Trans Fluid does a E4OD transmission take with the stock pan? Including filling the torque converter before installing...
Also what type? Mercon V?
If you drain every drain evey drop I believe Ford says it'll take around 16 quarts, including the tcase. But if you drop the pan and drain the tc then it should be right around 12-13 quarts.
And I'd use Merc/Dex III. That's what these transmissions were originally rated for and I've seen a couple guys grenade their e4od's from using Merc V.
973
11
Dropping pan, replacing filter and draining torque converter, you will need 13 qts.
Use Merc V, reccomended for the transmission BY ford.
I still dont believe the Merc III will grenade a e4od, Ford Motor Company themselves reccomend Mercon V and actually says 5w30 for engine oil too
973
11
Black150.. u agreeing with me?? lol
Black150
California Chapter member
169
So Cal
'hiding_smilie'
Lol, no i type slow i guess. I was agreeing with Skan. Then again, i'm not saying anyone is wrong.smiliestirthepot
120
You should get a 4r100 pan. They come stock with a drain plug.
