how big of a floor jack/jack stands do i need?
Ridgerunner
573
Stillwater Ok
Dumb question. How safe would a couple of steel wheels welded together be to place under the tires?
andym
Real men are fanatics
604
Roseville, CA
I can't really see it as being unsafe, really. Junkyards almost always use old rims to hold up junk cars and people are always crawling around under them.
Better than cinder blocks anyway. :)
Ridgerunner
573
Stillwater Ok
I have 3 ton floor jacks and used them on my truck recently and held it just fine,I just looking for extra security while under my truck
andym
604
Roseville, CA
Please tell me you meant to say "I have 3 ton jack stands" because if you are crawling under your truck and holding it up with floor jacks you are asking to die. Floor jacks can and will fail. They are hydraulic and there is nothing stopping the seals from suddenly failing and bringing the truck crashing down on your head and chest.
Ridgerunner
573
Stillwater Ok
I meant to say Jack stands I have 4 of them along with a 3 ton jack and I'm never under it without them.Sorry I worded it wrong.But I have known jack stands to fail too and that's why I was asking about the steel wheels.
Brian_B
blank
Lay the wheels down flat. I only use them on concrete. Then set the tire down in the curve again the welded in part. It will not move and is quite secure.
smokey
Hitech hillbilly
I have a 6 ton floor jack I use for most things and a few or the compact 3 ton one to change tires. Jack stands I have 4 6 ton and a few 3 ton. I use them unless I have to be under it alot, them I use 6x6 and 4x4 wood blocks.
