Alright fellas...let me first state, this is in my 79 Bronco, and no I don't have real gauges yet.
Now to the business part...I set the choke on my Bronco with a 351M, and the normally reliable dumby temp gauge jumps to the hot side instantly. The gauge has never gone past the 'O' in Normal even on the hottest days towing. I can manually bring down the needle if I keep my foot on the gas at around 2k rpm, but as soon as I let off the gas, the needle jumps up to hot again. Now as the engine begins to warm after about 3 minutes, the needle will start coming down on its own. And when the truck is fully warm the needle stays in it's typical spot that I said above.
That said, I'm running 20w50 because it needs it until the rebuild. So with the recent cold snap in single digits is this oil too thick upon start up? It was just fine 5 days ago when it was above freezing. So when it's as cold as it's been, should I just swap to a thinner oil?
Next I was thinking a possible sticky t-stat...but I've never had one stick at start up...so is this an option too?
Lastly, the radiator is on it's last legs with pinholes patched with JB Weld. Is it just time to replace the radiator, or should I just try flushing it? Although it's been my experience that flushing is the final death sentence allowing the crud to dislodge and show all new problems.
Another avenue is, I know that the cold can cause quirks to pop up in these rigs, and is it possible that the dumby temp gauge is gonna be one of those quirks? (I know reaching for straws)
So to recap...the truck runs really hot upon start up, but when it warms up, it's perfectly fine. So in advance, thanks for any tips, pointers, info.
