- Moderator
- #1
You're driving a vehicle with a growl/buzz/howling noise in the front. You happen to notice when you turn right, the noise goes away. Whats wrong, and where is the problem?
I can believe a growl or a howl, but a buzz?Hillary is driving next to you in the left lane. When you turn right, the problem fixes itself.![]()
R, the steering geometry is such that in a turn, the wheel of the turn side turns tighter than the trailing side. In a right turn the right wheel turns more sharply than the left, as the left wheel follows a longer arc, or track.carl, if you turn right, the load is taken off the right wheel, and instead transferred to the left side as the vehicle's inertia continues to try and go straight.
