Headers
TexasNomad
FTFS Designated DRINKER!
I like hookers.
Hooker and Thorley mainly...but if you have a 300...Clifford.
Only problem I have with Hedman is the fact that any application I've needed them for, the flange was anywhere from 1/8-1/4" thinner. On top of that, hedman's have a tendancy to rust out fairly quick. I've literally seen a set of hedman's go from brand new to rusted through in 9 months...and that's in the south. Now given...these are the cheapies and nothing nickel or ceramic coated...I just feel hedman is an inferior product.
384
wow ive never ever heard anything bad bout hedmans.
There's a reason why they're cheaper than most anything comparable out there.
Ben can say some thing bad about any thing :rolleyes:
Not true...I wouldn't say anything bad about Sanderson headers, Cherry Bombs, or Tom Woods driveshafts.
No long tubes ive ever installed ever fit. Flowtech, Headman, Hooker, had to cut the tubes and make em fit. On my 95 F350 5.8L E4OD 4x4, the flowtechs hit the trans pan, on my 92 F150, 5.0L E4OD 4x4,Hedmans, they hit the drive shaft, 88 Bronco 5.0L AOT 4x4, Hooker, hit the drive saft(didnt make them work yet) So I donno what to tell u, other then good luck.
flareside_thunder
7,812
246
I agree with Ben...the Hedmans rust out a hellova lot faster...if you want cheap and decent quality...get the Hooker's....You MIGHT have to notch your frame....
