Have parts-need clue!!
Hi,Newbie here.I have a '70 F250 Camper Special-w-360fe,no PS,noPB,4SPD-T18 with 3.73 gears. It's a clean 'ol unmolested truck deserving a restoration/update. I also have an '84 E250 Cargo -w- terminal rust&wrinkles. Does anyone know if the E250 can donate brake parts for PDB update. I also have an 84 F350-w-service bed&4-spd for parts if anyone is looking. Both doners are AZ trucks .Van cancer is from bad rear door seals&glued-in carpet.
radialarm
Clown of Death!
Can't help you, but welcome to the site.
Brian_B
blank
Is the 70 drum brakes all the way around? Does the 84 have front disks?
If both of those are true...the master cylinder will definately be different. No clue about the booster and rods in there or the pedals.
Maybe somone else will know if that part will swap over and bolt on.
Lost
PA Chapter leader
3,288
central PA
The Older truck will have king ping spindles and newer should have ball jionts. Also the old is probably a stright axle and newer independatnt .
But I bet the 78 79 stuff would work .
I have read some swaps done to the disc fronts on these.
As for linkages ect Can make them work changed little .
The rears other that spring perch u could swap rears to newer drums etc.
Good luck .
