- 35
- 2
Posted a need for a vacuum diagram of my 79 F250 400. After weeks of frustration with crappy idle and high smog readings, I finally got it running right. Original problem was a factory defect on the intake manifold, causing a huge vacuum leak. Fixed it and reinstalled it. Ran better but still a very bad idle. Carb rebuild did nothing, blah blah blah. Finally decided to replace the plugs and coil. WOW! Runs smooth as silk and smog readings are way below the limit.
Without some sort of analyzer, is there a way to test a coil? I replaced the platinum plugs with regular Autolite 25 plugs gapped at 44. Could that have helped? I'm not going to go back and try to figure out whether the coil or plugs fixed it, just curious.
My only remaining issue is that fifteen years ago I installed a dual exhaust system. 2 cats, 2 mufflers, etc. Now that I'm a "gross polluter", I have to return it to it's original setup, so it's back to a y tube and one cat/muffler. I LOVE California!!! Yeah, right!
