An interesting bit on my 77 F100 Custom, short wide, 400 2V C6.
I re-built the 400 at about 110k miles with a small compression increase and RV1 cam with no retarded timing. The rear gears were 2.92 ratio. Where the engine wanted to cruise at speed, the truck was going too fast in mph. I switched to a limited slip set of gears at 3.31 ratio. A much better balance of engine and land speed....and the mpg actually improved slightly. The truck is still a
for gas mileage though. It's mostly for utility and coolness these days.
Put in new leaf springs too. Much nicer without the Ford droopy rear end.
