Fuel filler hoses?
Manimal
California Chapter member
64
2
Hey everyone,
I havent been on here in a while(no ford until now)....anyhow, I just bought a 1979 F350 Supercab Ranger XLT w/460. I am in need of fuel filler hoses,but all I can find are listings for NON EVAP trucks???I have EVAP......WHAT IS THE DIFFERENCE? I cant see there being any unless it was a diameter issue.
Thank You for ANY help.
88
worst case scenario you could always buy a section of radiator hose thats the same diameter as the filler hose. i have a friend who did this and has never had any trouble with it. apparently its also cheaper as well. just a thought here
Tanks with evaporative emission control (EEC) have a vent hole in the tank above the fill connection. Check to see where the hose from that EEC vent goes.
If it does't tie into the FILL vent hose, then I would say the fill hose would be the same.
Manimal
64
2
Thank You. I am eliminating all the smog junk on this thing. I am moving to Illinois this coming spring and the truck will be registered there next week. So I am replacing the non-vented cap for a vented cap on both tanks. Thanks again.
Check your local Napa dealer for the "proper" fuel tank hose,they sell it here by the foot...much safer hose designed for gasoline use..
