Ford 400 pistons
wwporkchop
I called this place and they have 400 pistons 9.5 compression for $25.00!
Badger Pistons, LLC
7252 West 66th Street
Bedford Park, Illinois 60638
Phone: (866) 534-7601 or (708) 924-9460
Fax: (866) 834-2332 or (708) 924-9461
:wavey:
You might want to ask Tim about Badger...I could be wrong about this, but I thought they had changed ownership and were having issues with some of the products.
Wise man once said...."If it seems too good to be true, it usually is"....
wwporkchop
Also have factory 351m pistons
If you have a buieness account they said the factory 351m 8:1 compression pistons are $6.00 a piece!smiliewierdthread
wwporkchop
Using 351c pistons in a 351m
I was wanting to know if you can use 351c pistons in a 351m because of the diferate compression ratios you can get for the clevland! aldo would it cost a fortune to do! would like to put some 351c on my 351m or is it worht the time.:spank:
TexasNomad
FTFS Designated DRINKER!
No I believe the bore and stroke are different, you could use them but I think you would need a different Crank and other work done.
I've heard of guys doing it before...don't really know what all is involved, but it's a butt ton mix matched parts (I think theres even something from a Dodge 318 in the parts list). So with the stuff available today from TMI, KB, etc. I'd say you'd be time and money ahead for the same results just buying a prepackaged set up.
UNRULEE
^LARGE carbon footprint^
5,412
424
Coal Country, ND
Have a machine shop install bushings into the 351c pistons, then they'll work on the 351m rods.
Oh yeah while you're in there, upgrade to a 400!
gsxr1238
Be fast.....or be last.
When using the 351C piston,the hot setup was,they would bore the piston pin bore in the piston to .975 and cut a circlip land into the pin bore.This effectively made the pin float.Save the trouble and buy 400 pistons from TMI.
UNRULEE
5,412
424
Coal Country, ND
wwporkchop
pistons
Does anybody know what tim charges for 400 9.5compresion pistons and will they work ok with todays fuel?
