FINALLY getting somewhere LIFT KIT need some help thanks.
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
ok im getting 2 front leafs "superlift" 6 inches with poly bushings and center sleeves, dunno about the pitman arm yet.. from micheal if he cant find it its no biggie i can buy a new ones
now my question is... what else do i need..
longer brake lines
http://www.suspensionconnection.com/cgi-bin/suscon/95205.html
rear lift blocks.. will 5" be good for the 6" front leafs?
http://store.summitracing.com/partdetail.asp?part=SLF-1359
I -beam drop brackets
http://www.suspensionconnection.com/cgi-bin/suscon/20856.html
Sway bar relocation brackets
http://store.summitracing.com/partd...09+4294924929+215+4294881880+115&autoview=sku
shocks for 4-6 inch of lift
http://store.summitracing.com/partd...924929+215+400416+4294892146+115&autoview=sku
shock boot
http://store.summitracing.com/partdetail.asp?part=SLF-85280&view=64&N=700+115
Sway arms new bushings
http://store.summitracing.com/partdetail.asp?part=ENS-4-5106G
steering stabilizers
http://store.summitracing.com/partd...924929+4294925130+4294839070+115&autoview=sku
any thing else missing? thanks
dont ask why im doing it this way instead of gettina a lift kit. becuase its cheaper.. i got the front leafs from micheal good price...
if i do this it will be about 250$ less than the 6 inch lift kit
surewhynot
Rep whores make me sick
13,843
821
Florida
You may need to fab up or buy some type of traction bar for the rear. With the taller lift blocks, you might get some axle wrap. Also, I wouldn't get a steering stabilizer unless you need one. They normally just mask problems and can actually cause wear.
F 150Cobra
3,642
104
Aruba
ok.. yeah i will fab a traction bar.. ok so no steering stabilizers
Jurgen you typically wanna lift 2" higher in the front than the rear, if you wanna level the truck out. My lift kit is about 4" in front and 2" in rear, give or take, and as you can see my truck is fairly level front to back.
If it were me, I'd go some good lift springs instead of blocks... Like Tony said, you'll have some axle wrap problems with 4" on top of the stock blocks. It's just matter of spending the money on lift springs on spending it on ladder bars, either way you gotta spend some dough. If you want you could also use a thick stack of add-a-leafs instead of lift springs, but it might make for a rough ride.
Is it just me or do those drop brackets look kinda puny?
Here are my Pro Comp drop brackets:
A lot more steel on those Pro Comp brackets, no?
F 150Cobra
3,642
104
Aruba
No! Never stack blocks!
i know that.. thats why im asking.. wich block sould i get to replace the stock with the extra hieght? 4" ?? will be enough? i dont think so.. if te stock block already 4 or 3 " is
flareside_thunder
7,812
246
I gotta agree with Tony and like I told you last night...if you get blocks I will go down there and knock ur ass out.......blocks are just chitty and I've seen 3 inch blocks stacked and welded...hell I've seen em stacked welded and welded onto the axle housing.....go for the rearched lift springs.....better ride quality...unless you want a non airride semi......and yea Chris those drop brackets look puny as hell...I'm sure Tony could whip you something up fer less and be better quality...remember it's the safety of you and others you're taking into account...don't half-ass it...it's not a Chevy.
JR
surewhynot
13,843
821
Florida
The biggest blocks I would go with are 6 inch and even then you will need traction bars. The stock blocks are about 4 inches. How much total lift are you looking for in the rear?
Mr. Stroker
CASE IH
3,121
67
Michigan
Ive seen a lift kit on a mud bogger, had stock 4 leaf springs, and it had like 6 inch blocks but.... They was made of wood lmao! i laughed so hard when i saw that..
Lift springs. Lift springs. Lift springs. SING IT WITH ME NOW! Lift springs. Lift springs! :D
flareside_thunder
7,812
246
dude used to be a old guy around the corner from me who had an 83 ford f-150 4x4.......hot only did he shave down some landscaping 4x4's to do the rear lift...but he raised the truck up and sledgehammered 3 pieces of 2x4 into each coilspring....friggin idiot
JR
32
2
your talkin about the dude with the green 83 shortbed off of kismet he had 38s and cut out fenders it looked like a** and road like a**
biggin
