Finally Found My Buck Tag
I pulled up the carpet the other day to replace the dimmer switch, and the buck tag was on the floor underneath the carpet. The VIN number is stamped incorrectly. The manufacturer designation on the buck tag is "P", which should be an "R" for San Jose.
I realize that a lot of info on the tag is for manufacturing purposes only, but I would like to know if someone can give some info about the codes. The VIN itself has already beeen decoded.
Numbers off the buck tag are listed below.
F14SPBE8145 14-279
SX 133 BDY 4 BAR D
1C MLD LAR RCE TD
A XCJ P 6 93 BOTH
Possum
Georgia Chapter member
Ain't got no help fer ya there[confused]
BUT... wuts the difference between the VIN # and a Buck Tag??
The VIN is the number that the vehicle is registered by.(11 digits in this case)
The buck tag is a piece of stamped metal wired to some place on the body that is used for line employees to put the proper equipment on the truck as it goes down the assembly line. But the buck tag also includes the VIN number, which, in my case, is stamped incorrectly.
P = Twin Cities which was building 78-9's
I'll have to check for 77's
F14SPBE8145
14 = 14th week
or
DSO = Pittsburg
279 = shift 279
SX
133 = wheelbase 133
BDY 4 = Styleside box
BAR D = I forget
1C = Paint code = Black
MLD LAR RCE TD = Lariat with racetrack moldings
A = Trans = Automatic
or
A = Tilt column (adjustable steering)
XCJ + ? 4x4 with Power steering
P 6 + ?
93 ?
BOTH - Dual Fuel Tanks
I'll try to get back with the ? answers
Thank You very much, Dennis. The "P" in the VIN is misstamped. The tag on the door is an "R", for San Jose.
....................weird :)
